220 line
Old 07-25-03, 03:49 PM
dobes2
220 line
I want to put a 220 line into my garage, can a diy do this or should I hire a electric contractor
Old 07-25-03, 04:13 PM
HandyRon's Avatar
You've asked a pretty general question. So I'll answer similarly.
It depends, it could go both ways.
Old 07-25-03, 04:24 PM
dobes2
Let me ask this, I know a little basic wiring, how do go about doing this?
Old 07-25-03, 04:28 PM
Some things to consider: Do you have space in your existing panel, is the garage attached, semi-detached, or detached, will your panel carry the load, will the wiring be underground to the garage? How much load are you planning on the 220v line? Welder, table saw, electric water heater, lights, AC, heat?
Depending upon code in your area, it may well be a DIY project.
HTH
Old 07-25-03, 04:32 PM
dobes2
there is space in the box it is a100amp,the garage is attached I want to run a old delta10 in table saw
Old 07-25-03, 05:19 PM
HandyRon's Avatar
A 240V circuit is similar to a 120V circuit in that the wire has two insulated conductors and one bare ground. You size the wire the same as 120V, ie 15A for #14awg (or larger) and 20A for #12awg (or larger). You use a two pole breaker (double wide) and connect the two insulated conductors to each of the two poles. The receptacle looks a bit different than a 120V but the connections are similar. The wire installation methods are similar between 120 and 240V. What is it that you are unsure of?
Old 07-25-03, 05:53 PM
dobes2
going from the box out
Old 07-25-03, 07:22 PM
HandyRon's Avatar
Start at the library or your local home improvement store for some summer reading. Read up on the installation methods, and you'll be ready.
