Wiring 12 volt...
I have posed this question before. I would like to know how to connect a power car antenna using house power. I would like to connect the antenna to a switch...Thanks for your input and help
several ways to do it.
Connect it to a 12 volt power supply that has a switch on it.
Plug a 12 volt power supply into a receptacle that is controlled by a switch.
Use a battery and put switch in the line to the antenna.
