temporary service?
Old 08-11-03, 09:21 AM
B
temporary service?
I'm building a house, and would like to run power to my breaker box from the temporary pole meter.. distance is 125 ft and would like to run some lights and plugs, and the hot water tank on occasions. I have 300 ft of 10-2uf outside wire. my question is, can I take 2 each of 150ft and tie the ends together to make 1 wire. since 10-2 is 30amp rated, would that give a 60amp wire? thanks David
Old 08-11-03, 12:48 PM
Received 491 Upvotes on 403 Posts
No you can't do it legally.
Old 08-13-03, 01:50 PM
B
but,,, would it work?
Old 08-13-03, 05:29 PM
autotech156
NO I DON'T beleive it will.
None the less even if you were only to run it as a 30a circuit you should have 10/3 not 10/2. The grounding is pretty important!! (that is assuming your going 220v for the hot water tank)
Old 08-13-03, 06:33 PM
Very dangerous. You can't guaranty that the current will be split evenly.
Old 08-14-03, 01:05 AM
mcsew2k
Now you can tell from my other posts that I do not know much about electrical engineering but I know this sounds dangerous!
David
