Ground wire in a metal box
Old 08-18-03, 04:04 PM
T
New Member
When putting in switch's or recp. in a metal box should I connect the ground wire to the box or to the switch/recpt. Or pig tail it and connect it to both. Thanks
Old 08-18-03, 04:09 PM
C
Connect to the switch or receptacle.
Old 08-18-03, 06:22 PM
Received 1 Upvote on 1 Post
Both
Old 08-19-03, 07:33 AM
brickeyee
The box is required to be grounded. The mounting screws of a device are not allowed as the only ground. Pigtail and hook up to both.
Old 08-19-03, 10:09 AM
P
Art 250.148 (A), Metal Boxes reads-----"A connection shall be made between the Equiptment Grounding Conductor(s) and a metal box by means of a grounding screw or a listed grounding device"
Old 08-19-03, 10:23 AM
So if you mount an expansion ring/box on an existing box for more room, you would have to pigtail a ground on each one? Or since the expansion box is not a device, the standard mounting screws are sufficient to continue the ground connection?
Old 08-19-03, 11:05 AM
brickeyee
The mounting screws for attaching boxes together (gangable), or mounting a plaster ring provide an adequate ground connection.
