pigtails
Old 08-21-03, 07:45 PM
cthack1976
pigtails
I bought some pre assembled pigtails.(see pic) the awg is 12 but the wire is stranded. Is this ok?
I have 20a with 12 awg solid on my circuits.also they have "y" connectors on the end. Should i use these on terminal screws?
thanks
Old 08-21-03, 08:15 PM
pcboss's Avatar
Received 168 Upvotes on 147 Posts
There is no problem mixing the stranded with the solid wire. The stranded is more flexible and will fold back into the box more easily.
Yes, the terminals will go under the terminal screws.
Old 08-22-03, 07:35 AM
hotarc
When you wire-nut the two, lead the stranded past the solid just a little bit. It will help it catch better on the nut and prevent it from getting slid down the solid and making little contact.
Old 08-22-03, 09:00 AM
cthack1976
thanks for the tip
