Combining Circuits
Combining Circuits
Hello,
We are trying to install a 240 dryer outlet to our existing panel however all slots are being used. I'm curious if I calculate the possible load for a circuit if I could combine it with another in effect freeing another slot.. The way the panel is broken down is as follow. Two pole 40a, Two pole 30a, Two pole 30a, 6 - 20a slots, and 4 - 15a slots. Panel is 125a I believe. All are in use. How could I rework to free space for addtional two pole 30a. Without getting another panel or having to install a sub panel. There must be a way. Help is greatly appreciated.
Thank you
Thank you
In theory, you could combine two circuits into one if the load allows it, and if neither circuit serves a kitchen, bathroom, laundry area, or dining room. However, I doubt that this is the best solution. Other possibilities include:
- Using tandem breakers. If you tell us the model number of your panel, we can tell if it is designed to accept them.
- Installing a subpanel next to the main panel.
- Installing a larger main panel. This probably isn't the cheapest idea unless you are also upgrading the service size.
Sorry I didn't realize there was no image please just follow the address below for the scanned image. Thanks.
http://members.aol.com/vcolborn/scan08262003.jpg
I'm not an electrician so I'll let the experts weigh in as to whether there might be code issues, but ...
I have seen half width single pole breakers (1/2 inch wide instead of the normal 1 inch wide) at Home Depot here in Canada. There were Siemens for sure, maybe Square D also.
Since two half wide breakers take up 1 knockout on the panel face, you could replace the 4 15amp single pole breakers with 4 half width breakers then you will have 2 free spots for the double pole 30amp breaker for the dryer.
Might be worth looking ...
Here is a .pdf spec sheet for the Siemens breakers I mentioned.
I don't know if these work with your panel or if the panel mfr. has something similar.
http://www.sea.siemens.com/resident/product/SQT98.pdf
Would the Zinsco Two-pole twin on this page work? It looks to be as wide as the Zinsco single pole. It can be ordered as 15/20 amp so each side seems to operate separately.
http://www.breakerbroker.com/zinscobreakers.html
I have doubled up on circuits many times in older homes where some actually had nothing or only a couple lights on some of them. You should do some research and see where they go. Often bedrooms have little use. Some breakers are not meant to have 2 wires, in that case pigtail them. Here is a great site to do some research. http://www.homewiringandmore.com/index.html
