Electrical Conductor Color Codeing
I realize that Black, Red, Blue, Purple etc. can be used to indicated the hot conductor in a circuit but can different colors be used for Common (White) and Ground (Green) to indicate different circuits?
No, ground may be bare but in home wiring common must be white, but it doesnt mean that all wires you may find in a junction box may be common, someone may have used one as part of a switchloop although it should be remarked. When you see a white nutted to another color this is usually the case.
