another 3 way switch question
I have a question about wiring a three-way circuit to control two lights (please see the attached diagram). Which wires go on which terminals? How do the lights connect?
Thanks in advance!
Scott
Thanks in advance!
Scott
There is no way to make these connections with your current cable. Recable it in one of the following two ways, where "=" is a 14/3 and "-" is a 14/2:
Power-S1=S2-L1-L2
or
Power-S1=L1=S2 and L1-L2.
I prefer the former. The connections are easier and there is less chance of messing it up.
Power-S1=S2-L1-L2
or
Both switches are wired identically:
- White wires connect only to other white wires and not to any switch.
- The black wire from each 14/2 connects to the black screw (the "common") screw on each switch.
- The red and black wires from each 14/3 attach to the other two non-grounding screws.
- All bare wires connect to each other and are pigtailed to the green screw.
