Hottub wire
Hottub wire
What type of wire should I use, which will be buried and put in conduit, the grey stuff is what I should use?
so....
Wire type?
Conduit type?
18+ inches deep, anything else I need to know?
so....
Wire type?
Conduit type?
Type of wire should be THWN the (W) denotes wet location (all underground is considered wet)
Schedule 80 pvc Grey in color listed for electrical use (no plumbers pipe)
18" is fine
Plastic pipe make sure you pull a ground.
18" is fine
