Push button timer for bathroom fan
Old 09-11-03, 05:46 PM
kdturriff
My existing bathroom fan is operated by a std. on/off switch which is wired as a end of the run switch, can anyone tell me how to wire a push button timer switch which has 4 wires. (white, black, blue and green) Seeing as I am wired end of the run I cannot figure it out. Thanks.
Old 09-11-03, 06:46 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Check the timer manufacturers instructions. Most likely, it will not work unless you have a neutral in the box. If you have ONLY the hot and load wires in the box, you can install a spring-wound timer. they are only about $10 or so.
Andy
Old 12-16-03, 10:38 AM
kdturriff
Thumbs up
Thanks alot Andy, your instructions worked like a charm.
