Recessed Lighting?
Recessed Lighting?
Not sure if this is possible but...
I would like to put in recessed lighing in my kitchen ceiling, only I do not have attic space above. The ceiling is sloped with the roof directly above. Are there lighint options for this? Currently, I have two track lighting strips on either side so I don't think the wiring will be that hard to tap into. I'm just unsure about any clearance or other factors that need to be observed.
Thanks in advance,
bubba
Thanks in advance,
bubba
Thanks sparky! Not completely sure but I don't think running the wiring will be too much of a hassle because it's already run for the track lighting that's up. They are on opposite sides of the kitchen, which is how I would like to run the recessed lighting. Seems that the wiring can just be continued along the joists. Just a guess!
Bubba
Bubba
Yes if you only want to put lights in the same joist space it will be easy Though it will not produce very much light. With the remodel cans all that is required is to pre-wire the fixtures and cut a hole into the ceiling slip the wire into the hole and fish it to the next location and pop the light into the hole. Manufacturer provides good illustrations with remodel cans.
First, determine the direction of ceiling joists using stud finder.
Then, map out the locations of each can and determine whether drilling through joists is required or not.
If so, although it's not easy, you can cut out the closest and farthest holes from the power source and use a fish bit(a long metal rod with a drill bit at the end) to drill holes across the joists.
Then, hook a romex at the end of the bit and fish the wire thru.
The way I did in my kitchen is that I mapped out the can locations so that it'll minimize the joist drilling. But, I had to drill a few.
