Converting plug in light to hardwired with switch
Old 09-22-03, 09:51 PM
cccm
I'm wondering if it is possible/safe to take a wall-mounted swing arm reading light with a cord and plug and convert it to a hardwired version.
We've wired two 4" light boxes into the guesthouse we're building. We did not wire these boxes to a wall switch. I assumed we'd be able to find wall lights that were hardwire powered and switched at the light itself. I'm finding it very hard to locate such a light. www.rejuvination.com will add a switch to any of their wall sconces, but these are pricey.
The alternative I'm considering is converting a plug-in wall lamp such as the one seen at http://www.stacksandstacks.com/html/9662.htm to a hard wired version. This light only has power and neutral (black and white) wires -- no grounding wire. My light boxes have 12/2 routed to them. I was thinking of bringing the black & white wires from the cord inside the wall base, connecting them to my 12/2 wires, and then connecting my ground wire to a pigtail attached to a grounding screw which would be screwed into some hidden part of the metal wall base.
Is this a really bad idea, or could it work?
Thanks in advance for your help! Christina
Old 09-23-03, 06:44 AM
Received 1 Upvote on 1 Post
It is almost never acceptable to convert a cord-and-plug device to hard-wired or vice versa, and certainly not safe in this case. Why not simply install a receptacle in that box you were thinking of using for hard wiring it?
Old 09-23-03, 05:12 PM
cccm
Hi John -
Thanks for your reply. The box is a 4" circular light box and a standard recepticle box wouldn't cover the hole in the drywall or the box that is sitting there right now. I have recepticles nearby, but want to leave them available for guest's electronics, although I could mount wall lamps over the 4" boxes (to cover the holes) and plub the lamps into the nearby recepticles... I just perfer the cleaner look of no cords.
I'll probably either buy the pricey switched/hardwired lights or plug the cheaper ones into the wall.
Thanks again, Christina
Old 09-23-03, 07:14 PM
rickoh
lowes has a few that are both cord or wall mount that have the switch not sure now much they are though
Old 09-24-03, 06:16 AM
cccm
Hi rickoh -
Thanks for the tip! If you happen to see a stock number on those, please send it along. We have one nearby and that could be a great option.
Best regards, Christina
