box with two black wire only
I have a switch box with two black wires only in the box. I wanted to add another switch box next to it for a new light. How do you connect thsi? Thanks!
You left out a lot of details. It's easy to add a switch. It's harder if you want that switch to actually control something. For simplicity, I'll make all of the following assumptions. Please give me the correct information:
Post back with more information and we'll try to narrow in on the solution that is best for you.
- You want this new switch to control a new light.
- The existing switch controls an existing light.
- You live in a city where NM cable is allowed (perhaps not a good assumption given that you have only two black wires in your switch box).
- You plan on replacing the simplex switch with a duplex switch in the same box.
- There are no white wires in the back of the box.
- There are no grounding wires in the back of the box.
