lights dim! ground?
lights dim! ground?
Lights going brighter when a heavy load is applied is typical of a problem with the nuetral. The grounding conductor (safety ground, bare or green wire) does not cunduct excpet when a fault occurs. The grounded conductor (nuetral, white wire) cones from the POCO along with two hots for 120/240 service. If the nuetral has a poor connection you can see light brighten when a heavy load is applied to the opposite leg of the 120. Have the POCO check there connections first since it will not cost you anything. If they do not find a problem, check or hire someone to check the service entrance conductors.
i really suggest that the zinsco breaker really have to be replaced. i talked to the other person in the other fourm for professall electrican chat fourm area , and they say zinsco breaker are expesnive and they have alot of troble with busbar get damaged from weak concats . and i belive this might be over your head with this loadcenter box and i really suggest to get a electrican and help you to get the box replaced. my self i don't intercounterd zinsco breaker much at all. but my opion is better be safe side get a electrican and check out the main breaker and other wiring there i am sure that is the curpit is .
one quick warning if you heard buzzing sound or light go flicker when you touch main breaker or other breaker get a electrican there asap !!
merci, marc
merci, marc
lights go dim ground?
FrenchSparkey, Yeah your exactly right there is a lot of busbar deposit build up every time I change one,so I had room to move them down to an empty slot, a guy told me tha that same thing tha t they didn't use very good material in those boxes or the breakers. I will prob. upgrade to a 200amp box, any suggestions on what kind? Square D ? Thanks again for your reply you guys are great! Max.
