reset for motion detector
Old 10-05-03, 06:51 PM
billdad
I have lost my memory on how to reset my motion detector fixture. Recently, we had a power failure and my light came on when the power was restored -- and it stayed on. I have tried all the tricks I thought I remembered, but cannot get it to go off (other than by turning off the power switch). Can someone give me a clue on how to get it working properly again? I'll write it down this time. Hey, I'm getting old, OK.
Old 10-05-03, 06:56 PM
frenchsparky
there is a few tricks with motion dectors lumaires :
one is turn the switch on and then turn it off for 2 sec then turn it back on . it should be on motion sensor .
turn on and off switch about 3 or 4 time it will overide the motion dector sensor and end up stay on.
the third one is turn it off and wait about 15 to 20 sec and turn it back on it become like dusk and dawn set up
really first two will useally do the trick but depending on what type manufacter motion dector lumaire you have but really one of two will always do the trick
merci , marc
Old 10-06-03, 09:10 AM
Pierre
motion detector
hello,
Mine will stay on after a very short power failure and power has to be turned off for at least 30 seconds to be reset
Hope this helps
