Am I right? switch question
We are planning to install in a bathroom three sets of lights (same 20A circuit with #12 grounded
outdoor wire).
1- A recessed light in the selling
2- A set of lights around the mirror.
3- A set of indirect lights in a upper boxed space with plants.
And I’ll like to get control of all three sets through separated switches... but I don’t want a big
electrical box with three spaces... I’d like to put the three of them in a single multi function
switch. I saw one in my neighbor’s home, but that one is for the fan-heater-light.
Specific questions:
-Is there a similar kind of switch for the three sets of lights in my project?
-I saw one with screws for Ground, Hot (black wire), and three others. Is that the right one?
-If yes, How to install it?
(Here are my guess)
* Grounded pig tail to switch and box
* Entering Black to Hot screw.
*White pigtailed to each set of lights (not touching the switch).
*Black (or white with black marks? ) from each remaining crew to each set of lights...
Am I right?... or just going out of my mind?
Thanks in advance.
Guz.
outdoor wire).
Specific questions:
(Here are my guess)
Thanks in advance.
Guz.
Why would you use outdoior wire for a bathroom?
What you are suggesting sounds correct for the wiring of the switch.
Don't forget that you need a gfci outlet for a bathroom.
because
>“Why would you use outdoor wire for a bathroom...”
Because I think that the bathroom is a “wet” room and don’t want to mess with PVC conduit in closed walls, so I guess that outdoor cable can be better idea than indoor cable... kind of “extra” protection. And... because is the only one I have right now!, it was a big gift in deed. I still have about 300 ft and I’m almost done. The rest will be
spared for any contingency or further project.
Yes, I’m using GFCI in Laundry, Kitchen, Garage and Bathroom.
(My dryer is a natural gas one, can I use the same GFCI for both, Dryer and Washing machine? that GFCI and other for the Iron are the only outlets in that 20A circuit from a 200A Main Box).
Thanks for your reply.
