mini breakers
Old 10-15-03, 01:59 PM
phinphan
Question mini breakers
I have 3 open spots in my electrical panel, I would like to have a 220 outlet for my table saw and then 2 circuits of 110 outlets around the walls for A/C, and other tools, Can I use two of the spots for the 220 and then use mini breakers for the 2 110 circuits. Are there any other options for me to do what I want?
Are there any drawback to using Minis?
Where can I find Minis?
Thanks
(Tandem or twin breakers is what I mean by mini)
Old 10-15-03, 05:00 PM
Received 1 Upvote on 1 Post
Give us the manufacturer and model number of your panel and we'll tell you whether that panel accepts mini breakers. If it does not, your other options are a subpanel or a larger main panel.
Old 10-16-03, 07:45 AM
hotarc
Also, make sure your electrical service has the additional capacity needed to power your proposed circuits.
Old 10-16-03, 08:42 AM
phinphan
Cutler Hammer 200 amp
BR3040B200/CB203040
30 total slots, 27 filled
Old 10-16-03, 09:40 AM
Yes, you can use up to ten tandem breakers in this panel.
Old 10-16-03, 01:26 PM
phinphan
thank you very much.
Are there specific spots that the twins need to go? (ie like the bottom 5 spots?)
Old 10-16-03, 03:17 PM
R
The mini breakers, or tandem breakers, can go anwhere a regular breaker can go.
Since you have three open slots and want to add a 220 breaker and two 110 breakers (1 mini), I would just use the three open slots, assuming that there are two together for the 220 breaker.
Old 10-16-03, 05:32 PM
Skidmark
Look at the panel diagram on the door or inside. This will indicate where the tandem breakers can be installed.
