Ground conductor
Old 10-20-03, 04:49 PM
moe707
Ground conductor
Well, I ran the about 70 feet of the #4 stranded ground wire from the service SD homeline 100 amp panel to the metal water pipe that enters the basement in my house. Things looked good until I tried to hook the wire inside the panel at the neutral bus bar and I found out that it does not fit. It is larger than the neutral/ground slots.
Any ideas of what to do?
Moe
Old 10-20-03, 06:04 PM
frenchsparky
check your supply where you got the wire from i will give you the number for it
LK70AN
or
LK100AN that is Sq D number and it called netural and ground lug kit that will run few bucks ( less than 10.oo) and that shoud work
merci , marc
Old 10-21-03, 09:58 AM
Received 2 Upvotes on 2 Posts
Be sure when installing the ground lug that you sand to bare metal in the location where you will install it, and use self-tapping screws not sheet metal screws.
Juice
