Shower Light
Old 10-23-03, 11:08 AM
LAJO50
Shower Light
JUST INSTALLED KOHLER ONE PIECE ACRYLIC SHOWER STALL WITH CAP. HAVE ACCESS TO TOP FROM ATTIC WITH POWER SUPPLY AVAIALABLE. WANT TO INSTALL A LIGHT IN THE SHOWER. DOES THIS REQUIRE A SPECIAL FIXTURE I.E. SEALED FROM MOISTURE? OR WILL STANDARD RECESSED LIGHT WITH HIGH HAT SUFFICE?
Old 10-23-03, 12:22 PM
T
You'll need a special light for this (i.e. rated for shower use).
Old 10-23-03, 01:06 PM
You need a recessed light with a "shower trim", something like this:
http://www.junolighting.com/producti...=1162&subid=13
Most makers of recessed lights have shower trims for their various sizes. Styles vary a bit so you may want to choose your brand based on the shower trim you like.
Old 10-23-03, 02:30 PM
LAJO50
SHOWER LIGHT
VERY HELPFUL...THANKS VERY MUCH. LIGHT WILL BE IN ND WORKING BY SUNDAY.
Old 10-23-03, 04:20 PM
Received 477 Upvotes on 393 Posts
Stop shouting. Turn off your capslock.
