I need to pull electrical before the walls go up!
Old 10-25-03, 04:20 AM
B
OK...I am finishing the basement, and would like pull electrical for a future outdoor spa. I was told that 6/3 should work...but I will also run 12/2 to that same junction box and close it off. Is it ok to install the wires in the panel, and leave it with no breaker?
Also...I am planning on installing one junction box on the outside of the house, in the area we think we would want the spa...should I just use a simple PVC junction box?
Any advice, or suggestions on how to do this would be greatly appreciated.
I also posted a question in the spa forum...
http://forum.doityourself.com/showth...hreadid=148111
Old 10-25-03, 06:43 AM
Yes, Make sure that the wires are capped or taped to prevent them from becomming energised accidently.
Yes make sure the junction box is accessable and big enough for what you have planned.
Old 10-25-03, 08:04 AM
B
Capped or taped in the panel? I was thinking I would connecto them to the panel and not install a breaker until I am ready for the spa?
Also...I am glad you mentioned the size of the outside box...if I don't know how big I will need, what size would be safe?
Thanks.
Old 10-25-03, 08:33 AM
CSelectric
To clarify,
Yes you can run the cables into the panel.
When Sparky said t6 cap or tape the ends, he was refering to the ends of the wires inside the cable. Run the cable into the panel as you planned. Then strip a bit of the outer jacket away, and either wire nut or tape the ends of the individual wires. This will prevent them from becoming energized should they accidentally come in contact with the panel bus or the terminal screw of one of the existing breakers.
Old 10-25-03, 10:26 AM
B
Depending on which future spa you purchase and/or how you set it up, the 6/3 cable may or may not be code compliant. You would be much better off running a 1" PVC conduit.
Old 10-25-03, 12:32 PM
B
I kind of like that idea...should I run it just from panel throuth the top plat of the wall...and then the same from the junction box to throught the top plate of that wall? Sweeping 90's?
