Problem with 4-way light circuit
Received 0 Votes
I'm hoping someone will know what's wrong right off the bat... I've wired the a 4-way light circuit and powered it up, but it's not working properly. Instead of the 4-way switch turning the light on and off, it basically turns the circuit on and off (i.e. if the 4-way switch is in the up position, it allows the other two 3-way switches to work properly, but if the 4-way switch is in the down position, none of the switches work at all). I'm thinking that I have the wiring crossed somewhere, most likely at the 4-way switch. If it matters, the circuit runs like this:
power in->----light->-----3-way switch->---4-way switch->---3-way switch
Thanks in advance for the help...
Brian
Brian
have to becarefull here with 4 way switches it come 2 diffrent way to hook it up.
and some 4 way switch can look like double pole switch also.
any chance that can you get the manufacter switch name ?? if have number do bring it too and we can pinpoint it there
some 4 way swtich have double dark brass screw and some marked as 1 ,2,3,4 or common ( it will show double arrow there behind the device)
before you do that make sure you power down ( shut the power off first before you start messing around the switch )
some case it can slove by change the connetions by 90 degrees and it work some case but best bet is let us know what switch manufacter you have so we can steer you right there
merci, marc
merci, marc
Look closely at the back of the 4-way switch. Typically two of the screws are marked "input" and two are marked "output". The two wires from one cable should be connected to the two "input" screws, and the two wires from the other cable should be connected to the "output" screws. Mix this up and you have trouble.
Received 0 Votes
The switch is by Eagle Electric. I posted a picture of what it looks like at:
http://home.comcast.net/~mearsb/switch.jpg
If it's difficult to see, I have the reds from each cable attached to the top (dark) screws, and the whites from each cable attatched to the bottom (light) screws.
I'm fairly confident that the wiring at the other switches is correct. From John's response, I actually think that I should have a white and red from the same cable at both top screws, and the same from the other cable at both bottom screws. There's no marks whatsoever on the switch... only the colored screws.
Thanks for the help!
Yes, you are correct. Connect a red and white from one cable to the dark screws, and a red and white from the other cable to the light screws. The screw coloring is equivalent to the marking.
Working with 3 and 4 way switches can be fun if you know a few facts. Your diagram is a basic diagram to control a lamp from 3 locations. The internal configurations of a 4 way switch can be different for older switches verses newer ones. If you don't have the diagram of your 4 way switch, you can easily determine how your switch functions if you have a standard voltmeter with an ohmmeter function. The attached JPEG file has two drawings. The upper ones shows how the internal connections are made when the switch is in some position; the toggle control is either up or down. The lower diagram show what the internal connections look like after the switch has been flipped. Notice how the internal connections change. The connection straight across the top terminals now goes to the lower terminal on the output and the opposite for the connection across the bottom terminals, it now goes to the upper terminal of the output. Each time the 4 way is toggled or flipped the connections reverse. To test your switch, use a meter with a continuity checker and check where the terminals "switch to" when the switch is flipped. Knowing this you can properly hook up the input and output wires. Of course, the electrical power must be removed before the testing, or better yet remove the switch entirely and test it at some convenient place such as a table. Contrary to what some electricians may tell you, you can continue to add additional 4 way switches to provide additional control points at other locations. I once wired the overhead lights in a cabin so the lights could be controlled from six different doors entering the main room. Actually, the number of control points is unlimited. Hope this helps.
Received 0 Votes
After my last post, I went back and switched the wires that I thought I had backwards, and everything now works perfectly. Thanks to all of you for your help.
John, an extra thanks to you. I don't know if you remember, but you helped me quite a bit in the planning stages of this project. This last circuit finishes everything, and it all worked out great. The bathroom is done and also looks great. Your help (and others who offered advice) was greatly appreciated!
Brian
Brian
