3 Way switch installition
Old 11-03-03, 07:06 AM
Mooch
How do you connect the wiring for a 3 way switch? I've installed the light , the 3 way switches and the wiring. How do you connect it all correctly? Thanks for your help. Mooch 14
Old 11-03-03, 10:02 AM
bubinga1
Mooch,
I just did this job myself over the weekend and all went well.
It is pretty simple.
Basicialy there are two screws on each 3 way switch. that are a common color.
A (2) wire(s) is run from each connecting the common color screws.
Then the Power in wire goes to one switch,at the odd color screw,and the wire from the fixture goes to the other switch's odd color screw.
Here is a LINK
Thanks, Tony D.
Old 11-03-03, 11:10 AM
Mooch
Thank you
Thanks for the info Tony D
