wiring
wiring
Can I run my sheathed romex cable through the same holes in the studs that my copper water pipes are run through ?
There probably isn't a code determination on this mainly because the holes in the studs for the water pipes should not be that much larger than the pipe that you would even consider it. I think it would be a bad idea and would probably not pass inspection. Drill new holes.
