frozen lights in sockets how to remove?
Old 11-12-03, 07:02 PM
T
I have a chandelier that contains three lights, the base of the bulbs have frozen into the sockets.. When I go to twist them out the glass sleeve turns and starts to break.,
I then leave it alone knowing that the glass will break off the base and then I have to what?... Take a pair plyers and twist the hell out of the metal base and somehow ripppp it out of the socket?,
while standing on a step ladder.. There Must be A Better Way.... ????!!
Old 11-12-03, 07:35 PM
HandyRon's Avatar
After the glass breaks, cut a potato in half and push it onto the shards of glass sticking out of the base and twist.
Before you reinsert a new bulb, go to the electrical supply and purchase some no-ox goop. Shmear a light coat on the base of the new bulb before reinserting it.
Old 11-12-03, 07:58 PM
T
Thanks for the reply HandyRon,,
what is ' no-ox goop.' ??
Oh,, is it better to turn off the power in the panel?., or is the light switch adequate enough to turn off??
Old 11-12-03, 08:21 PM
bubinga1
I would turn off at panel in case it is wired wrong.
I believe "no-ox goop" is the stuff they put on aluminum terminals.
Thanks, Tony D.
