dimmer
Old 11-14-03, 10:35 AM
dimmer
I am installing a dimmer switch. The outlet has a white and black wire. The dimmer has a red,yellow and black wires. The instructions are unclear....which goes where? Thanks in advance.
John
Old 11-14-03, 10:41 AM
T
you probably picked up a 3 way dimmer. A "regular" dimmer only has 2 wires, usually both black (and pehaps a green ground).
Old 11-14-03, 11:12 AM
thanks for the fast reply trinitro....can I still use this one...and how would the wires hook up?
Old 11-14-03, 05:07 PM
Speedy Petey's Avatar
The instructions should be quite clear if you understand them.
To use a 3-way as a S.P. you use the "common" wire and one of the others, known as "travelers". Isolate the remaining as it has voltage when the lighs are off.
