Inductive voltage probe going off
Old 11-19-03, 01:14 PM
ALU_in_MN
What does it mean when the 3-light circuit tester shows no lights, both breakers of a circuit with a shared return are off, but the inductive voltage probe still shows current at an outlet until a third breaker is switched off?
(always have a backup!)
Does it mean that the shared return got shared again for another circuit. ?!?
Old 11-19-03, 02:37 PM
ALU_in_MN
Inductance is cool
It turns out one leg of the shared return circuit ran parallel to that third circuit for a while. The third circuit was powering the filters in my koi-filled fish tanks. Those filters pump water by using magnetic impellers.
Turn fish filters off on circuit #3, inductive voltage probe stops going off on circuit #1 & 2.
Probably doesn't help that circuit #3 was put in by someone who didn't believe in grounding anything, so everything runs off plug-in GFCIs.
Old 11-19-03, 05:08 PM
Received 1 Upvote on 1 Post
