Aluminum / Copper crossover
Old 11-20-03, 10:50 AM
ALU_in_MN
Is it safe to bring an aluminum leg of a circuit up to one side of a CO/ALR duplex outlet and continue on with copper on the other side?
<PRE>
| O O |
====< o >==== #12 copper
| O O |
----< o >---- #12 aluminum
</PRE>
It's getting cold out up here and I'm lothe to try pulling the aluminum until it warms up a little [snap!], so I'm looking for a 6 month fix 'till spring.
ALU_in_MN
Lets try that pic again...
Edited pic in original post
Old 11-20-03, 10:52 AM
ALU_in_MN
Sassa-frassaa HTML editors
<sigh>
Old 11-20-03, 11:55 AM
brickeyee
Yes, and probably better than the special splices required for an Al-CU joint. Putting the ground lines under seperate screws in a metal box works well also.
Old 11-20-03, 11:59 AM
bubinga1
It is my educated (somewhat) guess that this would not me a problem.
But lets let the experts have the final say.
You are, I take it referring to an outlet that is rated for aluminum /or copper wire?
BTY is there a program to help learn the drawings you guys do with the keyboard, or do you just figure them out for your self?
Thanks, Tony D.
