Disposal switch
Old 11-23-03, 02:16 PM
Stoppa10
Disposal switch
I recently discovered that the switch that my disposal is connected to is not working correctly. When I flip the switch to the on position, nothing happens. However when I put additional pressure to the switch, in the same direction, the disposal will work. Basically, as long as I hold the switch in that position, everything works fine.
Is this just a switch gone bad or something I should be more concerned about?
Thanks in advance for all of your help!!
Steve
Old 11-23-03, 03:07 PM
R
Bad switch. When you replace it, try using a heavy duty switch. You may have to get one from an electrical supply house rather than a big box.
Old 11-23-03, 03:09 PM
Stoppa10
Thanks!
Old 11-23-03, 07:01 PM
brickeyee
Just use a regular 15 amp snap switch. Most disposers pull well less than 8 amps. The price of a heavy duty switch is not justified.
