only top half of the outlets work (?)
Let me say this first: I know very little about wiring, other than electricity is a simple minded beast, in that it takes the shortest route possible.
My aunt purchased a home - built in the 50's or 60's. There are four outlets in the living room, but only the top "holes" work. The bottom "holes" do not. The rest of the house is fine.
Any suggestions?
Thanks,
Sampson.
Any suggestions?
Thanks,
Sampson.
Look for switch that "does nothing" I would bet they are controlled by that switch. It is unlikely for half of a switch to stop working.Post back if I am wrong an we will go a different route.
okay. thanks. i'll be at her home in an hour or two, and will look for a switch somewhere on/near the room.
Hopefully that's all it is. (still would wonder why a switch would control only the bottom half of four wall outlets...)
I'll let you know.
I'll let you know.
Now that you have solved your problem, you can prevent it from happening again. If you decide that you do not want all of these outlets to be half switched, we can tell you how to change all of the m, or just the ones you want to be always on.
Thanks, I guess I'll leave it alone for now, unless I'm asked to change it sometime in the future....
It is kind of nice for my grandma to be able to flick a switch for the lamps now instead of futzing with all the lamps themselves. She's 82, less leaning over, the better.
Thanks again.
Thanks again.
John,
Not if you left one outlet switched or if someone has added an overhead switched light... Don;t worry, I was not going to suggest changing all the outlets if there was no other switched light source...
