Three Wire Circuits
Three Wire Circuits
I had time on my hands today so I mapped out all the circuits on my panel (took the cover off). Found a few mistakes vs what the previous owners labels said. Also found that one 15amp leg of a 3 wire circuit appears to go nowhere. Tommorrow I'll start pulling outlets looking for the incoming 3 wire as I know where the other 15 amp circuit goes. I hope to find a "capped" hot.
It appears that I have 4, 15 amp 3 wire circuits. Adjacent breakers fed by 14/3 wire. None of the breakers are tied, and checking all recepticales none are multi-wired. It appears for space at the panel and easy of running wire, the electrician ran 3 wire and then split it into 2, 2 wire circuits at the first outlet / light
Is there anything that should be corrected here, I read in a few posts that even if there are no multwired recepticales, the breakers still should be tied. Is that correct ?
This is a perfectly normal and acceptad installation. I doubt there are any of the multi wire circuits terminating on a single device yoke so no handle ties are necessary.
On thing you will want to make sure of is that the white wires are pigtailed (wire-nutted together) rather than spliced thru the receptacle at the first box where the 3-wire cable is split into two separate circuits. Actually, it is a good idea, multi-wire or not, for all connections to be pigtailed rather than spliced thru the receptacles.
Although it does not sound like breakers with tied handles are necessary, thay are not against code either.
Personally I like them, so that there is no way that power can inadvertently be left on and somehow get to an outlet or switch I am working on.
