Remove base of broken light bulb from socket
Old 01-02-04, 11:54 AM
genroku
While removing a burned out light bulb from my range hood, the bulb broke, leaving the base in the socket. What can I do to remove the base so I can install a new bulb?
Thanks...S
Old 01-02-04, 12:07 PM
Moonpie's Avatar
Try reading this thread:
http://forum.doityourself.com/showth...hreadid=114714
Good luck!
Old 01-02-04, 12:08 PM
Four Mad Men
I've got two solutions that have worked for me:
1) Two small needle nose pliers. Just bend the base in enough to get the tips in and rotate both pliers at the same time. You might need a second person to hold the fixture if it wants to move.
2) If there is enough glass left attached to the base then you might also try half of a potato. Cut it in half and just push it onto whats left of the bulb and turn it while pressing down.
Old 01-02-04, 02:02 PM
R
You should, of course, turn the power off before inserting anything into what is left of the bulb (fingers, pliers, potato, whatever).
Old 01-02-04, 02:11 PM
Received 1 Upvote on 1 Post
And "turn off the power" means at the breaker box.
Old 01-03-04, 12:15 PM
genroku
Thanks to all who replied. It seems that the glass did not break at all, but just twisted out of the base of the blub...clean. So with some efort, I was able to remove the base without damaging the socket with a needle nose pliers. Happy New Year!
S:-)
