CO/ALR 4way switches
Old 01-10-04, 08:03 PM
Peller
I need to replace a 4way switch with a new switch. I have aluminum wiring so I know I need a CO/ALR switch. BUT I can't seem to find one. Can anyone point me to a place I might find one?
I'm using a standard 4-way for now since the replacement was an emergency, but suspect this cannot remain this way.
Any advice would be appreciated.
Old 01-10-04, 09:00 PM
Received 1 Upvote on 1 Post
If you can't find a CO/ALR 4-way switch, you can use CO/ALR wire nuts and copper pigtails. However, the CO/ALR switch would be preferable.
Old 01-11-04, 04:38 AM
W
Can't you use a regular switch and aluminum wire provided you use a de-ox compund?
Old 01-11-04, 08:59 AM
Received 515 Upvotes on 420 Posts
No you need ALU rated switch AND the anti ox compound.
Old 01-11-04, 09:21 AM
W
Oh, my bad. I was thinking about aluminum SE cable and the lugs on main panels.
Old 01-12-04, 09:00 AM
HandyRon's Avatar
weebee,
Even then, be sure the lugs are listed for aluminum terminations.
Old 01-12-04, 08:49 PM
W
Ya, I know, Don't know what I was thinking there!
