Run Flex from Attic down wall?
Any ideas of the easiest way to run my flex from the attic to the switch in the wall?
what do you mean by "flex"? Armor clad (BX)? Romex (NM)? I guess it doesn't matter too much, just how you connect to the box. Drill a hole in the top plate of the stud cavity where the switch is going to be. Cut a hole for the switch box and use a piece of sash chain or a fish tape to go from the attic to the switch hole. Attach the cable to the chain/tape and pull the cable in. Put the wire in the box and install the box in the wall with hold-its.
I am completely lost, not hard to do though.
I switch currently controls a receptacle and I am installing a new ceiling fan/light, there is no current light in the ceiling now. I need to run power from the exisiting switch to the new ceiling fan/light.
How do I run the wires up the wall from the switxch into the attic to the ceiling fan?
Why are you using flex? if it is a code requirement fine, use it. However, if you can use something else, such as NM-B, then I would do so, as it is much easier.
To run cable to an existing switch you must employ luck. Sometimes it takes a while. I have gone from both directions, from the switch and from the attic. Use a fish tape, a sturdy piece of wire or whatever you can think of and just keep plugging away.
Or, you could replace the existing switchbox which would make the whole process easier.
If I remember correctly from reading earlier threads, nanes72 is in the Chicago area--which I understand requires the 'flex'.
(Or at least doesn't allow NM--I suppose you can use conduit in that area???)
Some areas around Chicago allow NM cable, but you have to pretty far (50 or so miles away). Close suburbs require all metal electrical, either EMT or BX (for short distances only, but I've seen 50' runs of BX). If you have the height in the attic it's much easier to run EMT (even if you have to join a couple of pcs) rather then run BX. At least you can control which way the EMT is heading.
NM-B cable can be any color. it is only recently that some manufacturers have started using different colored jackets for their cable. Not all manufacturers do this, and those that do do not necessarily use the same colors as any other manufacturer.
I am not an electrician but have heard from one that if you are in Cook county, which includes all of Chicago and the 'close' suburbs, code calls for conduit. Outside of Cook county it varies. As mentioned above the further out the less likely the need for conduit.
What you really should do is call up your local inspectors office at your city/town hall and ask. I have found them to be very willing to answer such informational questions.
