Duct tape
Old 01-26-04, 05:04 PM
Duct tape
I replace a wall light and when I pulled out the wiring it had old electric tape on it. There were no bare wires, but the tape looked raggedy so I wrapped some new tape over it. I used black duct tape. Do I need to go back in and tear that duct tape out and replace with elect tape? Could I just put some more elect tape over it? Or is it ok that way?
TIA Steve
Old 01-26-04, 05:28 PM
Received 513 Upvotes on 418 Posts
You need an electrical box installed.
You need to replace the tape(all of it) with proper wire nuts.
Old 01-26-04, 05:43 PM
Received 1 Upvote on 1 Post
Electrical tape, or any other kind of tape, is not a proper way to connect wires. As Joe says, you must use wire nuts. Some people use tape over the wire nuts, but the connection should be made in a manner that this is completely unnecessary. If you are concerned that your wire nut connection is not secure, then make it again with a new wire nut -- don't tape over it.
Most books on home wiring show the proper way to make a wire nut connection.
Old 01-26-04, 08:16 PM
got it
Can do thx.
