NM Cable in Conduit?
Old 01-28-04, 08:27 PM
bdek
Question NM Cable in Conduit?
Can I use NM (Romex 12/2 w/ grnd. or 12/3 w/ grnd. ) cable in 1/2" EMT?
The conduit would protect a NM cable drop from approximately 6" below a wooden residential floor joist to an outlet box on a concrete block basement wall at about 48" above the floor. Would I still remain within the NEC conduit fill requirement using the above cables?
This technique seems to simplify the overall installation.
Comments appreciated,
Thanks,
Bob
Old 01-28-04, 11:34 PM
green jacket's Avatar
Your installtion will be code compliant by leaving the jacket on the romex down to the EMT connetor on the box, and having an adapter that has a romex connector on one side and EMT connector on the other side. An alternative is to use a regular romex connector, reg. EMT connector, and thread them into a rigid coupling of the correct size. Be sure to put a grounding screw in the box, and bond it.
The plan you have is good, I commonly install surface mounted basement receptacles in EMT, and need to convert to and from romex periodically for a homerun or lighting run.
good luck,
gj
Old 01-29-04, 09:10 AM
bdek
Thanks gj.
I will research the various conectors.
Bob
