Multiple Circuits In a Box
Can you have two (2) separate 15A or 20A/120V circuits in an
outlet or pull box box?
Thanks,
Bob
Thanks,
Bob
You certainly may, as long as both circuit are of the same voltage.
(meaning you can't mix a 277volt lighting circuit with a 120volt receptacle circuit in the same box.)
gj
gj
Yes, but you just keep the circuits separate. By that I mean that the hot wires and return wires from the first circuit must not connect to the other circuit. The ground wires, however, must be connected together.
Multiple Circuits in a Box
Thanks guys for the quick response to my question.
Appreciate the help.
Bob
Western NY
PS: Have you ever used a digital camera to illustrate a particular
problem or solution and then posted it here on the forum?
If so with what success and how are they accessed on the
forum? Can you post more than one photo at a time? I use
a digital camera and it has become a wonderful tool for the
exchange of technical info. I hope that I will be able to post
an "example image" of a real problem for all to see soon.
Photos speak volumes.
Looking for comments and suggestion as to the best way to
post a digital image on the forum.
Thanks again,
Bob
Bob
Western NY
Thanks again,
Bob
Voltage has no bearing on sharing a junction/device box. 110/220 circuits share boxes all the time.
Wiring from two different systems cannot share the same box. 120/240 circuits cannot be run with wiring from 277/480 circuits.
Art 300.3-Conductors, (C), Conductors of different Systems, (1), 600 volts or less-------" Conductors of circuits 600 volts or less, AC circuits and DC circuits, shall be permitted to occupy the same wiring enclose or race-way. All conductors shall have (the same insulation as the insulation of the conductors connected to the highest voltage)."
I saw this thread this morning but didn't post. I was hoping someone would post exactly what PATTBAA did.
On inserting pics. You need to upload a pic to your web server, usually your ISP. Then use this exact code, including the quotation marks, but replace the URL with your picture's URL:
{img src="www.yourpic'sURL.com"}
replace the { } with < >
