Circuit breaker replacement
Old 01-29-04, 12:51 PM
kk007
From a subpanel in the 2nd floor I ran an additional 12 Guage line with 15 Amp circuit breaker. The circuit breaker trips whenever two hair dryers are on at the same time. Can I replace the circuit breaker with a 20 Amp? Thanks for your advice.
Kevin
Old 01-29-04, 01:05 PM
E
Technically yes, but two simultaneously operating hair dryers are likely to trip a 20A breaker as well.
Old 01-29-04, 06:07 PM
Speedy Petey's Avatar
Agreed. Unless for some reason there is 14ga wire on the circuit, which there shouldn't be, there is no reason for this circuit to be on a 20 amp breaker.
