gfi for laundry appliances
Old 01-30-04, 01:02 PM
B
afaik, they are not mandatory, but i suppose a laundry room gfi is a good idea. if i install one, can i delete the separate ground strap running from the appliance to the water line?
Old 01-30-04, 01:48 PM
R
You should not have a ground strap running to the water line.
Is this an ungrounded circuit?
Old 01-30-04, 04:20 PM
hotarc
GFI's are not required for laundry circuits because of the possible of the washer causing nuisance trips. IMO, they are a good idea for other laundry room circuits, due to the close proximity to water.
Old 02-02-04, 06:26 AM
B
it is a grounded circuit. the ground strap was belt and suspenders in the first place, so it is more effort to remove than to leave in place.
why would a washer cause nuisance trips?
Old 02-02-04, 12:43 PM
hotarc
The washer could possibly cause nuisance trips due to the motor and coil windings. The theory is that there could be a current imbalance due to the slight delay that is incurred as the motor windings are energized.
Old 02-03-04, 10:12 AM
I had a nuissance trip from a dryer--the cold weather caused condensation on the aluminum exhaust piping and somehow was causing a fau lt. I respected it and inserted a short length of plastic tubing to "break" the conduction.
