Light switch connections
Old 02-01-04, 03:38 PM
blindmln
Question Light switch connections
Hello-
I am trying to switch out a toggle on/off switch to a dimmer switch. The problem I am having is that there are 2 brown wires attached to the toggles switch ( one attached on the top and the other attached on the bottom-opposite side). Then there is a yellow wire attached to the other screw on the bottom. The 2 brown ones are attached to 2 copper/brass collored screws and the yellow is aatached to a black colored screw.
How do I determine which is the ground, the positive and the negative. I don not have any testers and the closest electrical store is 1/2 hour away.
PLEASE HELP!!!!
Old 02-01-04, 05:21 PM
R
This sounds like a three way switch. However, you need to make sure before proceeding.
I recommend purchasing a tester. It's a good thing to have anyway. buy the kind with a neon light inside. This is more flexible than an outlet tester, and you can use it to test outlets.
However, anything that runs on 110 will work. You can use a regular lamp, just attach the wires to the plug. If you do this carefully this will work.
