Ice melting equipment
Old 02-03-04, 04:45 PM
B
New Member
Question Ice melting equipment
Having a severe problem with ice buildup in our gutters. Water is leaking through the walls. What can anyone tell me about installing an ice melting system for gutters/roofs?
Thanks,
Old 02-04-04, 07:16 AM
HandyRon's Avatar
There are many systems out there at the hardware stores. Essentially it is a small controller with a plug and a length of heating cable.
Plug goes into a receptacle (you will have to install one near the gutter), and the cable lays in the gutter.
Old 02-06-04, 06:42 PM
P
Received 2,106 Upvotes on 1,885 Posts
If you have trouble with ice daming you can zig-zag the wiring up on the roof. Generally you want to melt the snow/ice up on the roof past the houses walls (a couple feet).
