light cuts out on dimmer switch
Old 02-10-04, 09:02 AM
bg1229
my friend has 4 highhats on a dimmer.when dimmer is turned fully up one light cuts out 60watt bulbs in each. any suggestions?
Old 02-10-04, 09:18 AM
Received 1 Upvote on 1 Post
This is likely the thermal overload. Does the bulb come back on again for a few minutes after it cools down?
This seems unusual with only a 60-watt bulb, since most fixtures will accept this much (double-check the wattage of that bulb). Perhaps there is insulation contact with a non-IC fixture, or perhaps some other aspect of the installation is trapping too much heat. Or perhaps the thermal overload in the fixture is malfunctioning.
Old 02-10-04, 03:03 PM
imjerry
60 Watt bulbs
Two possibilities, One if the fixture was made for R type bulbs and the 60's are standard light bulbs it will overheat the thermal element in the fixture, R bulbs reflect heat down!! Secondly, I insulation in laying on top of the fixture, heat will be trapped and cause the thermal protection to open!!! A last possibility is that the thermal element is defective, most are replaceable from below!!!
Good Luck, BTW this is a quite common problem!!!
