thermostat wiring
Old 02-15-04, 06:08 AM
H
thermostat wiring
hi,
i have an oil burning forced hot air furnace. there is very old, rope insulated, 3-wire thermostat wire connected to my programmable thermostat. i want to replace it with newer wire, but I noticed something a little confusing.
the thermostat wire is joined together with wire coming from the furnace cut off switch. there are only 2 wires from the switch box. so, I have one thermostat wire that isn't connected to anything.
the thermostat seems to be operating properly (and has for over a year), but I'm not sure if the wiring is correct or not. I'm not sure if this is something that can be addressed in this forum, or if I just call an electrician, but if there is an easy answer, I thought I'd just take care of it.
Thanks!
Old 02-15-04, 08:15 AM
Speedy Petey's Avatar
For just a heating system you should only need two wires, usually red and white.
Explain what wires you have, what colors and where they are connected.
Old 02-15-04, 12:05 PM
P
Your description of the "old" thermostat cable suggests that the original connection was the M-H "Series- 10" heating-control which, at the time, was "standard" for automatic-control of residential heating- plants. Red, Black, and White wires connected to "R", "B" and "W" terminals.
The Series-10 thermostat had a bi-metallic element responsive to temperature changes, and on a "call-for-heat" the element would close in sucession, a "run" circuit, then a "start" circuit, which expains the 3-wire thermosat-circuit.
In "responding" to the rise in room-temperature, the element would first open the "start"-circuit, then the "run"-circuit. The bi-metallic element was a mechanical form of "differential" control. The purpose of a differential-control is to prevent "short-cycles" of frequent "On"-"Off" operations, a situation that would exist if the bi-metallic element had only a single "On"-"Off" contact.
Old 02-15-04, 06:35 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
"If it ain't broke, don't fix it!"
Your wire still works, and just because it is old doesn't mean it's not safe. Since it is only 24V, I say leave it alone.
Old 03-14-04, 06:17 AM
H
the old thermostat wires are yellow, green and brown. their thermostat connections are as follows:
yellow - RC
green - W
brown - G
the old yellow wire is connected to a white wire coming directly out of the furnace
the old green wire is connected to the red wire out of the furnace
the brown wire isn't connected to anything
