Adding outlets from a switch
Old 02-20-04, 07:07 PM
Mattmoose
Question Adding outlets from a switch
I am painting and replacing a vanity in a bathroom. The old vanity had outlets in the vanity, the new one doesn't. How do I wire from the switch to the new outlets?
Old 02-20-04, 07:10 PM
Received 1 Upvote on 1 Post
Tell us whether or not there is a white wire connected to the switch. If not, tell us if there is a white wire in the back of the switch box that is not connected to the switch.
Old 02-21-04, 04:45 AM
Mattmoose
There is a white wire connected to the switch. It is old wiring, and there is no ground wire evident.
Old 02-21-04, 11:16 AM
ampz's Avatar
Since there is a white wire connected to the switch you cannot connect a rececptecle from there.Is there a lightfixture over the vanity,if so then the feed going to the switch is in that box.You can run a line from there {provided there is room in the box} to a receptecle {GFCI} next to the vanity or medicine cabinet.
Old 02-21-04, 12:17 PM
I agree completely with ampz. Be sure you understand switch loop wiring before you start. When you look inside that box where the vanity light is, you will notice that the wires aren't simply matched by color. Make sure you understand why this is so.
