Remove Track Lighting Head, HOW?
Old 02-21-04, 10:22 AM
rj01
Any suggestion to remove Light Head from track. I tried turning the fixture and no movement. The Track is almost coming off the ceilng and the Head is not moving. What is the trick???
Old 02-21-04, 10:49 AM
ampz's Avatar
There should be a small tab {spring loaded in most cases} on 1 side of the head where it slides into the track.Slide this tab down towards the head & twist {where it meets the track} at the same time.
Old 02-21-04, 03:42 PM
Speedy Petey's Avatar
Is there a name on the head anywhere? This will help alot.
One that can be tricky is Halo. You pull down on the square sleeve right at the track. With the sleeve down turn the whole thing.
