Electrical
Received 0 Votes
What exactly does "will not work" mean? Does that mean the the switch physically does not move? Or that it does move up and down, but the receptacles will not turn on? Or that it does move up and down, but the receptacles will not turn off?
Did this just spontaneously stop working, or did somebody change something somewhere?
Received 0 Votes
So you replaced a switch with an identical switch? Is that right? Why did you replace the switch? Was it just to get one in a different color? You didn't touch the receptacles at all, right?
Did the switch control both halves of these three outlets, or just one half?
Can you answer the rest of my questions in my first post? Then can you describe all the wires in the switch box, both those connected to the switch and those not connected to the switch (if any)? Is this new switch a standard switch (says "on" and "off" on the lever), or a 3-way switch (blank lever)? Was the old switch the same?
electrical
The switch is a "on" "off" switch. I did replace the switch because of color. I have one red wire and one black with 2 other black wires attached to it. I just bought this house and I am perplexed at its wireing to begin with. All the recepticals work fine, just not the switch that is controlling them.
Thanks John
Received 0 Votes
I'm still unclear. Let's do one question at a time.
You say that the receptacles work fine, but the switch does not. Does this mean the receptacles are live even when the switch is off? Is this your problem? Yes or no.
Received 0 Votes
Okay. So you have four wires in the switch box. Three black wires are all connected to one screw on the switch (how?). And the red wire is connected to the other screw on the switch. And there are no white wires at all in the box. Is all this right?
Johns right, before replacing the old switch you should've made certain all was well with the wiring in the box where the switch is.This isn't meant for you to sound dumb but is the breaker tripped? If so there may be a loose wire or connection somewhere in the circuit.
Received 0 Votes
No, I don't think you need another switch.
Two questions:
(1) Has anybody, to your knowledge, ever replaced the receptacles?
(2) Are you sure the switch controlled those receptacles prior to you changing the switch?
Two questions:
Received 0 Votes
The problem is not with the switch replacement. It's with the receptacle replacement. Chances are excellent that somebody forgot to break out the tab on the receptacles when installing them. Please shut off the breaker, pull one of the receptacles out of the box without disconnecting any of the wiring, and describe the wiring in detail. Don't just tell me how many wires there are -- tell me exactly which wire is connected to exactly which screw.
