Aluminum Studs??
Old 02-27-04, 05:19 PM
mutinydave
Aluminum Studs??
I just finishing framing in my basement and am working on the wiring. I did most of the framing with wood 2x4s. However, on one wall I used aluminum studs. I have been looking all over for the grommetts or bushings that go into these studs (I think they are plastic or rubber) so that I can wire safely (without the wire resting on the aluminum stud itself). I am wiring with regular romex 12/2 wire. I cannot find these grommets anywhere!! I am from the Detroit area. Any idea if I can order these online and where?? Any direction is greatly appreciated!!!
Old 02-27-04, 06:25 PM
ampz's Avatar
Have you tried local electrical supply houses? One supply company that should be in your city is Graybar Electric.Good luck.
Old 02-27-04, 06:59 PM
Dave_D1945's Avatar
Received 1 Upvote on 1 Post
Where did you buy the metal studs? They should have the grommets - or know where to get them.
