Breaker size for lighting circuit
Old 03-07-04, 09:25 PM
D
Just finished wiring a new circuit for a group of recessed can lights (Halo brand from HD). I used #12-2 cable for the circuit and was planning to connect the circuit to an available 20 amp breaker.
However....
I noticed that the wire within the fixtures is stranded #14 or #16.
Does this mean that I must use a 15 amp breaker?
On a related note, the wire in the fixtures appears to be aluminum (it certainly isn't copper!) and given the concerns over using aluminum wire I wonder why it is used in most of the lighting fixtures I looked at in HD.
THanks,
DavidJ
Old 03-07-04, 09:38 PM
Received 1 Upvote on 1 Post
A 20-amp breaker is fine.
The wire in the fixtures is not aluminum. It's tinned copper. Scrape a bit of the wire with a pocket knife and you'll see the copper color.
Old 03-07-04, 09:40 PM
D
Thanks John,
Do you know what the benefit is of tining the coper wire?
DavidJ
