AFCI - Aluminum Wiring
I read an article in today's paper that said installation of AFCI breakers would be a good solution for houses with aluminum wiring, but that inspectors had stopped requiring AFCI's in new construction because they didn't work very well, and to wait a year until the new AFCI's come out, before having them installed. My house has aluminum wiring, and I have it inspected regularly and go around checking for hot outlet covers, but I would like to have the added protection of these AFCI's, which I had never heard of before. I've had a hard time finding electricians familiar with aluminum wiring in my area. I've had 4 different licensed electricians out here, and none thought I needed to replace my copper-only rated outlets with CO/ALR devices, which seems necessary to me. Does anyone know if there really is some kind of improved AFCI coming out in a year? Do the currently available AFCI's really not work very well?
Technology is always improving. The current version of AFCI works well. There is lots of information on the internet regarding AFCI breakers.
http://www.ul.com/auth/tca/fall02/Print/Print3.pdf
If your receptacles are not rated for AL wire, then they must be replaced or have copper pigtail added (with that pigtail spliced with an approved AL/CU wire nut).
