I have a problem with one of my glass fuses. I am using 4 - 30 amp fuses because the label on the circuit box (see link below for pictures) states 4 circuits 30 AMP 125-250 volts. One of the circuits in my house keeps losing power (about once every couple of weeks) but the fuse related to that circuit does not actually blow out it just gets warm. I just unscrew it and then screw it back in and the power comes back on. But last night, when I did that, I could see little sparks come from hole when I was trying to screw the fuse back in. My solution was to trade fuses with one of the other three and then it screwed back in with no sparks or problems. I am sure you are all cringing at my solution to this problem, but short of re-wiring my entire house what is the safe way to remedy this situation so I don't burn down my house.
My 1000 sq ft house was built in 1952 (no grounded outlets either)and I live in California.
Here is a picture of my circuit box:
[URL=http://home.comcast.net/~tinasnell/circuitbox.html]My Circuit Box Pictures[/URL]Read More
O.K., I'm in a sort of pickle here and need the honest to goodness truth about this. Several years ago my wife and I remodelled our main bath, which had but the minimum venting allowed, a window. We live in Wisconsin where it is not convenient nor advisable to open the window each time we take a shower or bath. I installed (ignorantly) a ceiling fan/light in the ceiling above the tub/shower to expedite the removal of moisture from the room. Now we are in the process of moving and I am wondering if the home inspector will most likely call attention to this as a safety concern. What recourse do I have in remedying this situation? I really don't want to have to move the unit.Read More
