LV and Mains in same box
Hi,
I am wondering if it is illegal and/or bad practice to mix a low voltage and a mains (240v in UK) in the same switch box.... They are MK grid switches, with 2 5amp standard SPST switches, and one is connecting a light bulb. I want the other to control a 12vdc circuit. Is it bad to do this? What about if I opto-isolate the switch from the rest of the LV circuit? if I can't do this, can you suggest any other ways? I'd really like to use the MK grid setup as they are used everywhere else in the house.
thanks,
computer
thanks,
computer
joed, not to get into a big thing but the issue is with conductor insulation rating and not voltage. You can mix low and line voltage but it is usually not a physically smart thing to do as they usually need to go to different termination points.
See NEC300.3(C)(1)
See NEC300.3(C)(1)
See NEC300.3(C)(1)
See NEC300.3(C)(1)
computer,
Zip style cord has a very low temp rating and should never be installed in any conduit or concealed in walls.
I have no clue about your systems in the UK so I really don't want to give you the wrong advice with regard to the rest of your question.
Sorry joed. I almost didn't write that post.
I should have assumed you knew that article.
I should also follw my first instinct.
